  • Richard Barg 358 posts 532 karma points
    Jul 23, 2013 @ 22:06
    Richard Barg
    Installed but datatype does not appear in 4.71
    @Matt,
    I am the project manger for our website.  We were able to successfully install Widget Grid, but it does not show up in the render control fro the datatype. There is no log file to show why. No error in other words.
    Do you have any thoughts on what might be happening and whether we might get it to work in 4.71?
  • Matt Brailsford 4125 posts 22224 karma points MVP 9x c-trib
    Jul 23, 2013 @ 22:11
    Matt Brailsford
    Hi Richard,
    You could always install it manually. If you extract the zip file, you'll have a dll and an aspx file. Just rename the dll to Our.Umbraco.WidgetGrid.dll and drop it in your bin folder, and rename the asp file to treePicker.aspx and drop it in /umbraco/plugins/WidgetGrid.
    Widget grid should then be available as render control.
    Many thanks
    Matt
    Jul 23, 2013 @ 22:26
    Richard Barg
    Matt,
    Thanks for the quick reply. We'll give it a shot and report back.
    Richard
    Jul 23, 2013 @ 23:27
    Richard Barg
    Matt,
    Here is how my developer responded. He said that he had previously done all you had recommended in your earlier post.
    "The installer already installed the treePicker.aspx in /umbraco/plugins/WidgetGrid and the Our.Umbraco.WidgetGrid.dll. The Widget Grid shows up as installed in the Installed Packages. The problem is that the Widget Grid does not show up in the Render control dropdown in a new Data Types."
    Any further ideas?
