  • Magnus Eriksson 122 posts 362 karma points
    Sep 06, 2011 @ 15:30
    Magnus Eriksson
    Parameter to XSLT file?
    If i use the:
    <umbraco:Macro runat="server" language="xslt" filelocation="/xslt/file.xslt" someparameter="foo" />
    I can't get the value in the XSLT file:
    <xsl:value-of select="/macro/someparameter" />
    Would be great if this was possible
    Regards,
    Magnus
    Sep 06, 2011 @ 15:46
    Rich Green
    Hey Magnus,
    You grab it like this
    <xsl:param name="currentPage"/>
    <xsl:variable name="source" select="/macro/foo"/>
    <xsl:template match="/">
    <xsl:value-of select="$source"/>
    <xsl:template>
    Rich
