  • Alan Mac Kenna 147 posts 405 karma points MVP c-trib
    Nov 05, 2018 @ 19:26
    Alan Mac Kenna
    GDPR & Consent for third parties
    Hi Alex,
    Would you consider adding a configuration value that will allow us to load the recaptcha script separately to the package?
    This would enable loading it when the user has explicitly consented to accept the third party services that a site has implemented, facilitating compliance with GDPR.
    It doesn't have to be the default, just to enable us to disable loading it automatically to facilitate loading it elsewhere.
    Alan
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Nov 05, 2018 @ 21:33
    Alex Skrypnyk
    Hi Alan
    Thank you so much for the idea, I truly said wanted to create 2 versions of the package - with scripts and without, but not because GDPR, more because if you add 2 forms with reCAPTCHA field, the page will load reCAPTCHA script twice what is really bad.
    Great idea with configuration, it really better than 2 versions of package :) just need to release this version.
    Alex
    Nov 07, 2018 @ 13:19
    Alan Mac Kenna
    Super! Yes it occurred to me that that would help solve the duplicate script issue too :)
    Thanks Alex
