  • Bengt Thomassen 5 posts 86 karma points
    Dec 03, 2018 @ 13:18
    Bengt Thomassen
    Invisible reCAPTCHA is not invisible
    Hi, i just implemented this plugin, and got a Invisible reCAPTCHA API from my customer, but the captcha is not invisible in my form. When i enter the form-page the reCAPTCHA pops up, and there is also a badge down in the right corner of the browser. Do i need to implement some css to make it invisible?
    FYI: I have implemented the InvisibleRecaptchaPublicKey and InvisibleRecaptchaPrivateKey in UmbracoForms.config :)
    I asked my customer to double check the API, and they was sure it was the right key for invisible reCAPTCHA.
    Invisible Recaptcha is visible
    Recaptcha badge in the right corner
    Details:
    Umbraco version: 7.12.2
    Umbraco forms: 7.0.4
    Plugin version: 1.0.0
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Dec 03, 2018 @ 14:16
    Alex Skrypnyk
    Hi Bengt Thomassen
    Invisible means no checkbox to click. If you see a popup each submits - then you very look like spammer no this site :)
    Here you can find a way to hide a badge from Google - https://stackoverflow.com/questions/44543157/how-to-hide-the-google-invisible-recaptcha-badge
    Alex
    Dec 03, 2018 @ 14:22
    Bengt Thomassen
    Hi Alex,
    Ahh, i totally misunderstood the "invisible" concept. i tought it was supposed to be "smart" and not popup at any time. I am probably spamming to much, so that's why it keeps popping up every time ;)
    Thank you for your fast reply! h5yr! :)
    Dec 03, 2018 @ 14:32
    Alex Skrypnyk
    For most users it's invisible, a popup shows only if your behavior or IP looks not perfect :) so the system is pretty smart and really cool.
    Totally agree with you that badge looks awful thing and it's better to hide it.
    Dec 03, 2018 @ 14:41
    Alex Skrypnyk
    But according to the reCAPTCHA Terms of service (that you must have agreed), you must inform visitors about the reCAPTCHA implementation on your site :
    And from the Google Terms of Service
    These terms do not grant you the right to use any branding or logos used in our Services. Don’t remove, obscure, or alter any legal notices displayed in or along with our Services.
    Dec 03, 2018 @ 14:56
    Bengt Thomassen
    Thank you for the information. I should probably follow the rules then :)
    My solution was to inline the badge, so it doesnt render down in the corner of the browser.
    In: \Views\Partials\Forms\Themes\default\Fieldtypes\FieldType.InvisibleReCAPTCHA.cshtml
    I added data-badge="inline" to the "g-recaptcha"-div.
    It looks better now:
    Thank you again, Alex!
  • Namrata 8 posts 78 karma points
    Apr 02, 2024 @ 03:06
    Namrata
    Hello Bengt Thomassen,
    I am also trying to implement an invisible recaptcha custom field. However, there are some issues that I am facing while submitting the form. Was wondering if you remember implementing the customfield type and mind sharing it ? I am quite interested to know how did you managed to generate the form token and continue the rest of the workflow after form submission
    Some context about the issue I have added an event listener on form submission which prevents the default form behaviour. However, in the data-callback when I submit the form (after a successful generation of recaptcha token) it just doesn't move forward with the default workflow.
    I have tried even implementing a timer function to refresh the recaptcha token every minute. However, the image dialog always shows up after every minute which then doesn't make any sense to have an invisible recaptcha.
    Namrata Sanger
    Apr 04, 2024 @ 06:19
    Bengt Thomassen
    Hi Namrata, I have looked for this code in some old repositories, but i cannot find it- sorry :( This was probably for Umbraco 7 way back in the days when the umbraco forms did not have an build in recaptcha v3.
    Apr 04, 2024 @ 18:38
    Namrata
    No worries Bengt Thomassen,
    It got it working. Thanks for the response tough :)
