  • ecommerce 2 posts 52 karma points
    Nov 07, 2013 @ 07:07
    ecommerce
    Extension not found or permission denied
    Hi, Ive installed this package to one of my staging website, but its not working, im getting Extension not found or permission denied error.
    <error>
    </error>
    I'm using Umbraco 4.7.2, is it compatible?
    Can you help please?
  • Nigel Wilson 945 posts 2077 karma points
    Nov 07, 2013 @ 07:48
    Nigel Wilson
    Hi there
    Sorry to hear you have experiencing problems.
    I believe the functionality should work in 4.7.2 although cannot 100% confirm.
    From the info provided I am not sure where you are seeing the message - are you able to provide additional information.
    Also as per http://our.umbraco.org/FileDownload?id=6172 are you able to verify that the setting in your umbracosettings.config does exist.
    If so does the URL look correct ?
    If so can you copy the URL and paste into a browser - what response is returned ?
    Cheers, Nigel
    Nov 08, 2013 @ 06:44
    ecommerce
    Hi, thanks for your reply.
    I’ve figured out.
    But I should have been more clear. I was seeing that message when accessing the URL in the umbracosettings.config.
    But the reason it could not find the extension is because I have a lowercase rewrite rule applied to my IIS.
    so when accessing https://mydomain.com/base/restExtRecycleBin/DeleteItems/10/30.aspx (Capitalized) it was rewriting to https://mydomain.com/base/restextrecyclebin/deleteitems/10/30.aspx (Lowercase) and returning that error I mentioned.
    The solution is to apply an exclusion in the rewrite to anything inside the /base/ folder.
    thank you
    Nov 09, 2013 @ 23:51
    Nigel Wilson
    Hi ecommerce - pleased you figured out the issue.
    Maybe tick your last post as the solution so it appears as resolved.
    Cheers, Nigel
