  • aaronb 97 posts 116 karma points
    Dec 29, 2010 @ 00:02
    aaronb
    Can create first topic, but it doesn't stay and I can't reply
    I've installed the latest version of uforum on 4.5.2, and I have set up a single member group and type. I am able to log in to the forum, and create a post. But when I try to reply to that post, the reply doesn't show up. If I leave the page, I seem to have no way to find my post again (I don't know if it's saving). There's no forum list, just the intitial forum screen when I return to it, where I can create a new post again.
    Nothing has showed up in the content tree, not sure if it should or not.
    Any ideas?
    Dec 29, 2010 @ 10:07
    Morten Bock
    That sounds a bit strange. You content tree should have the main forum nodes, but should not have any post/comment nodes. Those are saved in the database only.
    Could you check if any rows have been created in the three database tables: 'forumForums', 'forumTopics' and 'forumComments'?
    Could you also describe which node you have in the content tree, their property values, and the url's you visit when you create a topic/comment?
  • Martin Richards 1 post 21 karma points
    Jan 09, 2011 @ 23:42
    Martin Richards
    I'm seeing something similar...
    • Installed Umbraco 452
    • Installed uForum_1.0.0.0bIII_net3.5
    • created a forum
    • Set up post and admin groups
    • View Forum
    • Login
    • Post
    Login takes me to http://www.coachingnetwork.org.uk/discussion-forum.aspx which is pretty minimalist - the only option is create new topic.  I choose that and post, and get to http://www.coachingnetwork.org.uk/discussion-forum/1-post-3.aspx (title was "post 3", as I'd uninstalled and tried again!) where I can add a reply, but this doesn't show up, and if I go back to the start page, no topics are listed.  The three tables are populated.
    I note that though I have 4 templates (master, forum, display topic and new topic) I only have one document type, uForum, and the only allowed template for that is forum - should there be more doc types, or more allowed templates?
    Martin
    Jan 10, 2011 @ 08:53
    Morten Bock
    I will have to see if I can recreate this.
    Could you post the contents of the three tables, and maybe a screen dump of your content tree?
  • Robby Maher 8 posts 28 karma points
    Jan 26, 2011 @ 20:01
    Robby Maher
    Has there been any progress on this?  I too am seeing an issue where posts are not showing up.
    Jan 26, 2011 @ 20:20
    Morten Bock
    I have not been able to reproduce, so any additional info you can provide would be very helpful.
    Jan 26, 2011 @ 20:32
    Robby Maher
    Hi Morten!  Thanks for your help.  I have installed the latest beta of uForum, for .net 3.5.  When I installed the forum, the database tables were created successfully.  What do I need to do in the content section to get a forum up and running?
    I looked, but couldn't find any documentation on this package.  If I am missing it, please post a link, and I will check it before continuing.
    What I have done so far, is create a content node with the document type: uForum and template: uForum_Forum, and allowed all authorized users to post and administer, and allow creation of new topics.
    It is giving me an xslt error: Error parsing XSLT file: \xslt\uForum-CommentsList.xslt
    umbdebugshowtrace gives: Value was either too large or too small for an Int32.
      at System.Convert.ToInt32(Double value)
      at System.Double.System.IConvertible.ToInt32(IFormatProvider provider)
      at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
      at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltArgument(XmlQueryType xmlType, Object value, Type destinationType)
      at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
      at System.Xml.Xsl.CompiledQuery.Query.<xsl:template match="/">(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, XPathNavigator {urn:schemas-microsoft-com:xslt-debug}current, Double {urn:schemas-microsoft-com:xslt-debug}position, Double {urn:schemas-microsoft-com:xslt-debug}last, IList`1 {urn:schemas-microsoft-com:xslt-debug}namespaces) in D:\Websites\UmbracoCMS\xslt\uForum-CommentsList.xslt:line 25
      at System.Xml.Xsl.CompiledQuery.Query.<xsl:apply-templates>(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, XPathNavigator , Double , Double )
      at System.Xml.Xsl.CompiledQuery.Query.Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
      at System.Xml.Xsl.CompiledQuery.Query.Execute(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
      at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlSequenceWriter results)
      at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer, Boolean closeWriter)
      at System.Xml.Xsl.XmlILCommand.Execute(IXPathNavigable contextDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter results)
      at System.Xml.Xsl.XmlILCommand.Execute(IXPathNavigable contextDocument, XmlResolver dataSources, XsltArgumentList argumentList, TextWriter results)
      at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
      at umbraco.macro.GetXsltTransformResult(XmlDocument macroXML, XslCompiledTransform xslt, Dictionary`2 parameters)
      at umbraco.macro.GetXsltTransformResult(XmlDocument macroXML, XslCompiledTransform xslt)
      at umbraco.macro.loadMacroXSLT(macro macro, Hashtable attributes, Hashtable pageElements)
    Jan 27, 2011 @ 14:05
    Morten Bock
    There is not much documentation, and time is limited at the moment. If you are just starting out, you might want to take a look at nForum instead; http://our.umbraco.org/projects/website-utilities/nforum
    It seems to have a bit more momentum.
