  • Rasmus Ebler Simonsen 25 posts 48 karma points
    Aug 18, 2009 @ 00:38
    Using the Forum Package
    Hi All
    I had a homebuild forum on my old Umbraco 3.0.x installation and after upgrading to 4.0.x it would no longer work (since it used a MassMailer). So I tried to install the uForum package. There are 2 forum packages but I guess they are the same. When I install uForum 0.0.7 I get this error:
    Item has already been added. Key in dictionary: 'newtopic'  Key being added: 'newtopic'
    I have tried to uninstall and install again, but I can get around this. Can any of you tell me how to get the package installed?
    /rasmus
  • Chris Koiak 700 posts 2626 karma points
    Aug 18, 2009 @ 13:43
    Chris Koiak
    I occasionally see this, but usually a page refresh or Application Pool refresh fixes it. Have you tried both?
    Aug 18, 2009 @ 17:54
    Morten Bock
    Sounds like it is trying to add a template or macro that already exists. Have you tried manually deleting the templates/macros that the package installs?
    Aug 18, 2009 @ 18:40
    Thx Morten
    It turned out that I had a Template named Create Topic. After a couple of install/unstall's it had become 3 templates all named Create Topic.
    After deleting them and a macro named Forum (which could be harmful. I dont know) I succelfully came to the next step. Database installation, which also went well. Now I will start experimenting with the package.
    /rasmus
