  • Gordon Saxby 1465 posts 1887 karma points
    Aug 25, 2009 @ 18:16
    Gordon Saxby
    Does uForum require Runway?
    I want to add uForum to an existing Umbraco v4 website, which does not use Runway.
    Will uForum install / work OK without it?
    Aug 25, 2009 @ 19:27
    Dirk De Grave
    I don't think there's dependencies between those, at least that's how it should be. One should be able to install a package, regardless of previously installed packages, unless specifically specified as a prerequisite. I can't find any? Can you?
    And btw, why not just install it and see how it goes. It's probably not being installed on a live server, so, it wouldn't hurt too much I guess...
    /Dirk
    Aug 26, 2009 @ 21:16
    Gordon Saxby
    I agree that there shouldn't be any dependencies unless stated ... but considering the "newsness" of the product and minimal (?) documentation, I thought I'd just ask the question, on the off-chance that someone actually knew the answer ;-)
    Sep 02, 2009 @ 12:47
    Gordon Saxby
    Just to finish this post off, in case others are wondering ... uForum does not REQUIRE Runway but it is setup to reference the Runway placeholders in it's template.
    I don't use Runway, so I just took the core of the uForum templates and put it into my own templates.
