  • Kaj 41 posts 73 karma points
    Feb 20, 2010 @ 10:13
    Kaj
    Can´t get create a topic to work??
    Do I have to have any special Member name inlog to get that to work? In that case what is the membername?
    Feb 20, 2010 @ 19:29
    Morten Bock
    Have you set up membership on your site? uForum only requires that a member is logged in. It does not look at membertype or usergroups, only that a member is signed in.
    You need to setup you own login controls. They are not supplied with uForum. For a quick way of doing this, take a look at my blogpost on the subject here:
    http://www.mortenbock.dk/blog/2009/04/01/setting-up-membership-in-umbraco.aspx
    Hope this helps.
