  • Aaron Powell 1708 posts 3046 karma points c-trib
    Jun 28, 2010 @ 09:20
    Aaron Powell
    CSV import problem when going previous/ next and mappings
    Umbraco Version: 4.0.3
    CMSImport Version: 1.0.3
    I came across a problem today when using CMS Import and a CSV as my data source today. I selected CSV as my import source and then got all the way to the step where you select the mappings.
    I didn't realise that i needed to set a header row, so I modified my CSV, used the "Previous" button to go back and reupload my CSV with a header. When I got back to the mapping step it didn't realise that I'd changed the underling CSV so I wasn't able to redo my mappings and I had to restart the process again.
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Jul 01, 2010 @ 11:44
    Richard Soeteman
    Thanks for reporting this will be solved in 1.1
