  • Shannon 148 posts 171 karma points
    Jan 25, 2011 @ 04:05
    Shannon
    Installs fine \ CMSImport not visible in Developer
    I have tried to install 4.6.1 and I don't have anything in the developer section. I have logged out and back in and there are no errors in the event log. Am I doing something wrong?
    Jan 25, 2011 @ 08:07
    Hi Shannon
    Can you see the three DLL's in the bin folder, where the name starts with CMSImport?
    Jan 25, 2011 @ 15:50
    Shannon
    Looking back over the install, everything installs correctly but there isn't a link for the installation wizard inside of the Dev section. I can click the link after the install that guides me to the installation wizard but there just isn't a link in the dev section that I can go back to.
    Jan 25, 2011 @ 15:56
    Shannon
    Package install error: System.IO.FileNotFoundException: Could not find file 'C:\Projects\UmbracoFinal\App_Data\5e2ded14-c259-41ac-9ac2-b17b3a1815ef\DeleteItem.aspx'. File name: 'C:\Projects\UmbracoFinal\App_Data\5e2ded14-c259-41ac-9ac2-b17b3a1815ef\DeleteItem.aspx' at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.Move(String sourceFileName, String destFileName) at umbraco.cms.businesslogic.packager.Installer.InstallFiles(Int32 packageId, String tempDir)
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Jan 25, 2011 @ 17:24
    Richard Soeteman
    You have to logout and do an IISReset then it should be in the developer section. I've created workitem http://umbraco.codeplex.com/workitem/29960 for this.
    Thanks for reporting the missing file in the free version. I'll remove this for the next release but shouldn't be an issue. If logging out and an IIS reset doesn't work please check that cmsImport records exist in the AppTree table, if they 'don't exist. perform a manual install as documented in the manual http://www.cmsimport.com/documentation.aspx
    Richard
    Richard Soeteman
    Richard
    Jan 26, 2011 @ 04:00
    Shannon
    That did it, thanks. I am currently using Community Server 2007. Do you have any SQL scripts I could run to import both blog post and members into Umbraco?
    Jan 26, 2011 @ 05:54
    Richard Soeteman
    Nice ypou got it working, could you mark this issue as resolved?
  • Scott Hugh Alexandar Petersen 349 posts 164 karma points
    Mar 14, 2011 @ 22:32
    You sure that you cannot just recycle pool?
    I just tried and it worked as well - thing is that not many has the "power" to do an iisreset! However recycling the pool is more accessible in the end :) (oh and I did not log out but it worked and I did a reload nodes and then it showed up)
    On my windows 2k3 iis6 2cpu (2.6ghz each) and with 4gig mem it's quite slow importing around 200 rows (around 11 minutes). Is that normal?
    Mar 15, 2011 @ 05:53
    Richard Soeteman
    Hi Scott,
    Only restarting the APP pool gave me some issues as well. Regarding performance. It;s not normal that it takes 11 minutes. should be less than a minute. Lot of sites on that machine?
    Richard
    Mar 15, 2011 @ 16:43
    Okay, well define many sites :)
