  • Anders Brännmark 228 posts 280 karma points
    Aug 20, 2009 @ 07:30
    Anders Brännmark
    Removing whitespace when using qoutes as seperator
    Looks like it removes whitespace when using qoutes on import of members. I had a CSV file with the following setup:
    Login;Name;Email;Password
    1;"Kalle Persson";"kalle@kalle.com";"sdsdd111"
    When importing it removes the whitespace in the name "column". When removing qoutes it works. Needed qoutes as in email the data was incorrectly format with ; sometimes.
    So how do I remove 500 members the easiest way?
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Oct 08, 2009 @ 16:03
    Richard Soeteman
    Hi Anders sorry about didn't get back to you. I've missed this post somehow. I'm not understandig your problem I think. Which character in the above example gets removed?
    I have a usercontrol btw which removes all members. Do you still need that?
    Richard
  • Sean Mooney 131 posts 158 karma points c-trib
    Dec 18, 2009 @ 19:01
    Sean Mooney
    I have the same problem when I use CSV and " as the Text Indicator
    This is the csv that is generated from Excel
    column one, column two, "column three with spaces", column four
    And when I import it, column three gets imported as: columnthreewithspaces
    Feb 16, 2010 @ 09:21
    Richard Soeteman
    HI All,
    Missed the post again :-( I've uploaded a new release where this is solved.
    Richard
  • James 1 post 21 karma points
    Mar 10, 2010 @ 11:26
    James
    I am trying to import some content into an Ubmbraco instance, and I am suffering from the same issue.
    The content is exported with "some text", but all whitespace is removed during the import from the CSV so it becomes "sometext"
    I am running 4.03, which I believe is the most current. Can you tell me which release will have this issue fixed.
    re:I"'ve uploaded a new release where this is solved."
    Jim
    Mar 12, 2010 @ 20:29
    Richard Soeteman
    Hi Jim,
    The newest CMSImport V1.0.3 should have fixed this. This one is only available from our.umbraco.org/projects the normal repository uses the old UmbImport 1.0.2 package.
    Richard
