  • Vincent Baaij 95 posts 344 karma points c-trib
    May 22, 2013 @ 12:59
    Vincent Baaij
    Date problem in 6.0.5
    In my source filt I have the following element:
    <ObjectCreateDate>2011-02-10T10:07:00</ObjectCreateDate>
    In my import steps I've setup the createDate as follws:
    createDate =ObjectCreateDate with format yyyy-MM-ddTHH:mm:ss
    The createDate is still being set to now.
    Also tried the format without the 'T'. Didn't work either.
    I really need to import the original date. How to fix?
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    May 22, 2013 @ 13:02
    Richard Soeteman
    Hi Vincent,
    Yes sorry. I have seen it myself also. The underlying API of Umbraco V6 doesn't allow to set the create date anymore. It always falls back to now. I will remove this option in a future release. Waht you can do is create a separate property and use that in the site to display the create date.
    Richard
    May 22, 2013 @ 13:16
    Vincent Baaij
    Richard,
    Thanks for the swift reply. That's exactly what I just tought up.
    Stupid I didn't think about checking the V6 API.
    May 22, 2013 @ 13:22
    Richard Soeteman
    Hi Vincent,
    Yeah I always want to avoid using the database directly instead of the API.
    Richard
    Aug 21, 2013 @ 14:02
    Richard Soeteman
    Hi Vincent,
    Sorry for the delay on this but I've just released version 2.4 of CMSImport which ignores the create date in Umbraco V6
    Hope this helps,
    Richard
