  • Bex 444 posts 555 karma points
    Dec 16, 2015 @ 14:18
    Bex
    Method not found: 'Void CMSImportLibrary.Helpers.DataHelper.MoveDocument
    I am running Umbraco v6.1.6 with a licenced copy of CMS Import 3.3
    When I try and move a media item I get the following error: error msg
    Importing data seems to work fine. Is there something I may have forgotten to install/set?
    I did have the prev version installed but I thought it might be a version thing so I tried uninstalling that, but the site totally crashed saying it was missing the dll for cms import so I reverted the site and installed it over the top. I am saying this in case it makes a difference.
    Thanks for any help
    Bex
    Dec 21, 2015 @ 11:32
    Bex
    Any help would be much appreciated here. Even a point in the right direction as this is a live site with a problem!
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Dec 24, 2015 @ 07:03
    Richard Soeteman
    Hi Bex,
    Sorry for the delay I don't receive notifications on these posts anymore best to email [email protected] for urgent issues. There is no MoveDocument in CMSImport Library so I think you have upgraded from V2? Make sure all old dll's are gone then it should work fine again.
    Hope this helps.
    Richard
