  • Jay 425 posts 652 karma points
    Nov 09, 2016 @ 16:13
    Jay
    CMSImport 3.5.3 with Umbraco V7.5.3 (issue with MNTP)
    I'm having issue importing from an xml and I have the below tag for an MNTP property. The rest of the fields seems to port over alright apart from MNTP fields.
    I have the below property which is an MNTP, I've checked the nodeIds in it and it exist on the site but the property is empty after import. Any idea?
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Nov 10, 2016 @ 05:58
    Richard Soeteman
    MNTP tries to match on nodenames. could you try that?
    Best,
    Richard
    Nov 10, 2016 @ 08:04
    Jay
    Aha that explains why. I'll check that this morning and let you know.
    One more thing, how do CMSImport knows which nodename to map to if there's two same nodename that exist on different path? Just curious
    Thanks Richard
    Nov 10, 2016 @ 09:43
    Jay
    Hey Richard,
    I've tried swapping the id in the xml with node name like the below and tried to reimport. But it's still not picking up. The node name is as what it is on the site (no duplicate of similar node name either)
    <filters><![CDATA[Business,Accounting,Human Resource]]></filters>
    Nov 11, 2016 @ 07:47
    Richard Soeteman
    Not sure if CData could be an issue and are you using xpath as configuration of the MNTP. Sometimes this is causing an issue. Best to try with a rootnode in config during import.
    Nov 11, 2016 @ 08:14
    Jay
    where do you set the rootnode in the config during import?
    Thanks Richard
