  • Steve Borg 28 posts 99 karma points
    Jun 08, 2017 @ 06:57
    Steve Borg
    Is too long for it's underlying datatype
    I got the following error when trying to import a product property into the product extended content:
    2017-06-08 07:43:34,956 [P24584/D2/T176] ERROR CMSImport.Merchello.ImportProviders.Product.ProductImportProvider - CMSImport:Product 'Product1' failed to import
    System.ArgumentException: value '<PriceCollection><Prices><Price SKU = "PROD1SKU....' is too long for it's underlying datatype
       at CMSImportLibrary.Helpers.PropertyValueValidator.ValidateNVarCharProperty(Object )
       at CMSImportLibrary.Helpers.PropertyValueValidator.ValidateProperty(PropertyInfo propertyInfo, Object value)
       at CMSImport.Merchello.ImportProviders.Product.ProductImportProvider.(ImportActions , IProduct , ProductType , Dictionary`2 , AdvancedSettingFieldOptions , PropertyInfo , Object , ImportState  , Boolean&  )
       at CMSImport.Merchello.ImportProviders.Product.ProductImportProvider.(ImportState , ImportState , Int32 , ImportStatistics )
    The property is designated a text area and the size of the string I am trying to add is 6390 characters and consists of XML which includes <, >, ", -, = and / characters.
    Any idea why this is failing to import?
    Best regards,
    Steve
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Jun 08, 2017 @ 08:48
    Richard Soeteman
    Hi Steve,
    This message comes from the datatype. What happens if you use a different property editor?
    Best,
    Richard
    Jun 08, 2017 @ 16:02
    Steve Borg
    Hi Richard,
    I created a new textbox property in my document type and re-configured the import to use that and it gave the same problem.
    Which property editor should I use? Please note, as I didn't make it clear in my original post, that this is a Merchello product import into a property of the extended content.
    Best regards,
    Steve
    Jun 09, 2017 @ 06:48
    Richard Soeteman
    It is weird since extended content is stored as ntext and the property should also be ntext and kept out of validation.
    Is it an environment you can share with me? If so please email support@soetemansoftware.nl.
