  • Richard Thompson 100 posts 336 karma points
    Feb 18, 2019 @ 13:00
    Richard Thompson
    Problems importing RTE content
    I'm using CMS Import 3.7.7 to migrate some content from an Umbraco 6.2.6 site to an Umbraco 7.13.1 site.
    Some of the nodes are failing on the bodyText field (an RTE field). I've stripped back the content to just content that errors, here are some examples:
    <h3>When?</h3>
    <p>Every Tuesday (except 16, 23 Dec and 17 Feb).</p>
    <h2>Where?</h2>
    <p>Meet by the potting shed, London Road estate, N10 8LK</p>
    I can't see anything that would obviously cause a problem. When I leave the RTE empty these pages import without issue.
    The error I'm getting is
    Error :Conversion failed when converting from a character string to uniqueidentifier.
    This is caused by an SQL exception I guess when trying to save the property data.
    Any ideas on this or is there anything I can try?
    Thanks Richard
    Feb 18, 2019 @ 16:02
    Richard Thompson
    I've run the SQL profiler to capture some of the errors that I'm seeing during an import. I'm seeing errors around the following queries
    Select id, text,Path FROm umbracoNode where uniqueID = 'filename.jpg'
    Select propertyEditorAlias from cmsDataType where propertyEditorAlias is null
    Invalid column name 'propertyEditorAlias'.
    Select alias from cmsContentType where masterContentType is null
    Invalid column name 'masterContentType'.
    That last query is invalid as the cmsContentType table doesn't have a masterContentType column.
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Feb 19, 2019 @ 07:21
    Richard Soeteman
    Hi Richard,
    This was a bug indeed and fixed in a hotfix to be included in 3.7.8 already.
    If you install both packages below the error should be gone.
    Cmismport package : https://www.dropbox.com/s/a2ooybno5qnspw1/cmsimport37_8.zip?dl=0 Umbraco data provider : https://www.dropbox.com/s/p0t0dkhfj2svey8/CMSImport.UmbracoDataProvider.zip?dl=0
    Best,
    Richard
    Feb 19, 2019 @ 13:38
    Richard Thompson
    Hi Richard,
    Thanks for the prompt response.
    I've given the new version a try and I've been able to import content that was previously erroring.
    Richard
    Feb 19, 2019 @ 15:28
    Richard Thompson
    I'm running the import of another document type at the moment and having checked the log file I'm seeing instances again of:
    There is also the following information which hopefully may help:
    Error Number:8169,State:2,Class:16
    Feb 19, 2019 @ 15:34
    Richard Soeteman
    The last error doesn;r ring a bell, Sure you are still using the hotfix, no dll's on deploy? There is a tryparse now that checks first if the referenced item is a guid before starting to convert it.
    Feb 19, 2019 @ 15:41
    Richard Thompson
    You're absolutely right. I had originally installed the package via NuGet so when I restarted the site this afternoon it's used the old DLLs from NuGet.
    Thanks again.
