Just found out how this package could help me, though heard of it before. I've downloaded the package to my machine and installed locally and the Recaptcha is showing up fine, but Label is not available to select for a Field Type:
As you can see, Recaptcha shows twice but only because I had previous installed that stand-alone type prior to installing the package. Is there any known reason for this, and a fix? Am I perhaps just missing something on my part here?
Thanks, and I look forward to getting the best out of such a simple package (currently have 'Description -> HiddenField' things all over the place which is drastic (and breaking saving of form data).
Label not present after installation to 4.7.1.1
Hey Grant
I believe you are having the same difficulties and myself. A different thread is trying to address it. Check it out here.
