  • John Ligtenberg 53 posts 214 karma points
    Mar 11, 2013 @ 15:59
    John Ligtenberg
    Recaptcha not working with with Umbraco 4.11 and Contour 3.0.6?
    Is is possible to use the Contour Contrib ReCaptcha fieldtype with Umbraco 4.11 and Contour 3.0.6?
    I keep getting the error:
    The partial view '/umbraco/plugins/umbracoContour/Views/Fieldtype.recaptcha.cshtml' was not found or no view engine supports the searched locations. The following locations were searched:
  • Adam Jenkin 71 posts 226 karma points
    Mar 11, 2013 @ 16:06
    Adam Jenkin
    There is no razor file in the contrib project for this field type, if you add the form from contour using the usercontrol macro it should work.
    I had a look making cshtml files for the recaptcha and AreYouAHuman captcha field types but not sure how or where to add the validation logic.
    Adam
    Mar 11, 2013 @ 16:42
    John Ligtenberg
    Thanks Adam. I just updated to Contour 3.0.9,  which als works with Umbraco 4.11, and this has solved the problem. Both the ContourContrib Recaptcha and the Recaptcha included in Contour 3.0.9 work.
