  • Arjan H. 226 posts 463 karma points c-trib
    Jan 15, 2014 @ 21:59
    Arjan H.
    Any reason why it wouldn't work on Umbraco 6.1.6?
    I'm running Umbraco 6.1.6 on IIS 7 (Windows 2008). I've installed Cultiv EnvironmentIndicator v1.0.2. The .dll is present in the /bin directory, the .browser file is present in the /App_Browsers directory, and I've added the following appSettings key to the web.config:
    <add key="environment" value="dev" />
    I'm not seeing any errors, but I'm also not seeing the indicator?
    Jan 15, 2014 @ 22:22
    Arjan H.
    Also, I checked your assembly code with .NET Reflector, and I noticed a small type-o:
    string str4 = string.Format("<div style=\"height: 3px; widht: 100%; background-color: {0};\"><span style=\"font-size: 1px; line-height: 1px;\">&nbsp;</span></div>", str3);
    "widht: 100%" should be "width: 100%".
    Jan 16, 2014 @ 12:43
    Arjan H.
    To make the package work in Umbraco 6 the cultiv.environment.browser file should be updated:
    <browsers>
      <browser refID="Default">
        <controlAdapters>
          <adapter controlType="Umbraco.Web.UI.Pages.UmbracoEnsuredPage" adapterType="Cultiv.EnvironmentIndicator.IndicatorAdapter" />
        </controlAdapters>
      </browser>
    </browsers>
