  • Ron Brouwer 273 posts 768 karma points
    Feb 25, 2010 @ 19:19
    Ron Brouwer
    Why?
    Why would you go through all that trouble?
    You can use:
    <body id="node<umbraco:Item field='pageID' runat='server'></umbraco:Item>" class="blabla">
    Ron
  • Heather Floyd 610 posts 1033 karma points MVP 6x c-trib
    Feb 26, 2010 @ 19:54
    Heather Floyd
    Hi Ron,
    I din't know inserting a macro into a template was a lot of trouble. ;-)
    The main thing I wanted was to be able to get the template name as a class, which you can't access via umbraco:item. Also, sometimes I have experienced issues with inserting things into html tags, so it was just simpler for me to do it all in one shot.
    Heather
    Feb 27, 2010 @ 09:17
    Ron Brouwer
    Hi Heather,
    It's true that the item normaly can't go into a tag.
    The only thing is to replace " for ' then it works fine.
    I thought that the @template worked but it returns an id.
    Another posibility is to use a placeholder and set the class in each template.
    But the problem is already solved, so thanks for sharing.
    Ron
    Feb 28, 2010 @ 05:42
    Heather Floyd
    Thanks for the tip about the single quotes vs. double-quotes. I will keep that in mind.
    ~Heather
