Petr,
I have followed your instructions and cannot get past the database page on the configuration wizard.
Is there something else I need to do?
I don't try it with umbraco 5, but it should work with 4.7.1
You must have SQL Express installed, and modify permissions for asp.net account on app_data folder.
I am using 4.7.1.1.
Sql Express is installed and permission are correct. It turns out the problem was your version of SQL (which I downloaded) didn't match mine.
If I create a db in SQL and then detatch and use that it works fine.
Database connection initialisation failed.
Petr,
Petr,
I am using 4.7.1.1.
