  • Yarik Goldvarg 35 posts 84 karma points
    Jul 22, 2012 @ 07:58
    Yarik Goldvarg
    Upgrade to 4.8
    Hello
    After upgrade to 4.8 i get error.
    Could not load control: '/usercontrols/IndexStatus.ascx'.
    'Examine.Providers.BaseIndexProvider' does not contain a definition for 'SupportUnpublishedContent' and no extension method 'SupportUnpublishedContent' accepting a first argument of type 'Examine.Providers.BaseIndexProvider' could be found (are you missing a using directive or an assembly reference?) at System.Web.Compilation.AssemblyBuilder.Compile() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at umbraco.cms.presentation.dashboard.OnInit(EventArgs e)
  • Darren Ferguson 1022 posts 3259 karma points MVP c-trib
    Jul 22, 2012 @ 09:34
    Darren Ferguson
    Yup - package hasn't been updated for 4.8
  • trfletch 598 posts 604 karma points
    Aug 15, 2012 @ 13:38
    trfletch
    Just so you know I get the same error on Umbraco 4.7.2 which is a shame because this is a great package for keeping your indexes in check.
  • Asif Malik 203 posts 339 karma points
    Sep 19, 2012 @ 11:43
    Asif Malik
    Hi Darren do you have any plans to upgrade this to work with 4.9 ?
  • Stephen Roberts 47 posts 516 karma points c-trib
    Oct 29, 2012 @ 15:37
    Stephen Roberts
    This package has now been updated to support the recent changes to examine and thus 4.8
    Oct 30, 2012 @ 15:09
    Tom Fulton
    Awesome, thanks Stephen!
  • Steve McGill 6 posts 57 karma points
    Nov 05, 2012 @ 14:40
    Steve McGill
    A big thankyou from me too!
