  • Fergus Davidson 309 posts 588 karma points
    Aug 01, 2012 @ 18:09
    Fergus Davidson
    doesn't seem to work in 4.0.4.2
    hi
    compatibility list suggests that this should work in 4.0.4.2, but when i install, i get a fatal error in all frames, i have removed the dll but the error was something like '.. uses runtime version later than the site..'
    is there a previous version that would work for me??
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Aug 02, 2012 @ 12:32
    Jeroen Breuer
    Maybe you can try the source code and make sure it uses .NET 2.0 or 3.5?
    Jeroen
