  • Wesley de Roo 38 posts 142 karma points
    Sep 26, 2013 @ 16:14
    Wesley de Roo
    Implementing Donut Caching and MVC part in existing solution
    Thnx for contributing this package.
    I was trying to implemt the the MVC part with DonutCaching in a existing solution. I only implemented the BaseModel and the defaultcontroller for now. The caching works, only problem i have is when, for example, i call the url domain.com/news/newsitemB I get the same content when I previously called the url domain.com/news/newsitemA. It caches exact the same content when the page has the same view.
    I'm using Umbraco 6.1.5.
    Templating tree:
    Master
    - Homepage
    - Submaster
    -- Newsitem
    -- Newsitems
    When I start your solution and looked at the news section, that problem does not occure.
    Do you know what is going wrong? Or can you give me a direction to search for.
    Sep 26, 2013 @ 16:22
    Jeroen Breuer
    101
    Have a look at the Global class in Umbraco.Extensions/Utilities/Global.cs. This makes sure that DonutCache works per url.
    In your DonutOutputCache attribute set VaryByCustom = "url".
    In Umbraco.Site/Global.asax update Inherits to your own Global class. For example Inherits="Umbraco.Extensions.Utilities.Global".
    Than it should work :-).
    Jeroen
    Sep 26, 2013 @ 16:32
    Wesley de Roo
    Thats it! Didn't checked that.
    Thnx!
  • Matt Taylor 873 posts 2086 karma points
    Jan 24, 2014 @ 15:39
    Matt Taylor
    2
    I had this problem too so I tested it in the original source I'd downloaded from github.
    I found the individual news items were only displaying the first cached version so it would be a good idea to change the Umbraco.Site/Global.asax to Inherits="Umbraco.Extensions.Utilities.Global" there too.
    Matt
