It probably won't work with v7 yet because the Hybrid Framework also comes with a lot of packages (which contain datatypes) that aren't compatible on v7. It also has extension methods for those packages again so things like that won't work yet.
Once v7.1 is out (with things like an improved Media Picker and Image Cropper) I'll also start using v7 and I'll make a new version of the Hybrid Framework with full focus on v7.
The Model/Controller part will probably stay the same with some small improvements.
Great framework + Umbraco 7
I just wanted to say a big thank you !
I love the architecture of this framework. It's high quality and exactly what I was looking for.
Did you try in with Umbraco 7 ? (not all just the custom Model/Controler part) ?
Fabrice
I give some more info about Umbraco 7 at the end of this video: http://www.youtube.com/watch?v=rubA5k5cnxE
Jeroen
Can't wait for the improved Media Picker and Image Cropper. Want to use V7 massively but can't because these are missing atm :(
Looking forward to V7.1
Craig
Thank you very much for the infos and the link to the video
