  • Poornima Nayar 106 posts 276 karma points MVP 6x c-trib
    Apr 10, 2014 @ 15:07
    Poornima Nayar
    Queries
    I am looking into using this package for a client of mine and have some questions. Any help greatly appreciated.
    1. we have a dev domain on xxxx.local and staging on xxxx.id-staging.com in addition to the production domain. How many licenses do we need? What would be the cost like?
    2. We are on Umbraco v6. Is the package compatible with the Umbraco version
    Poornima
  • Spyros Spyriadis 46 posts 70 karma points
    Apr 10, 2014 @ 15:26
    Spyros Spyriadis
    Hello there,
    Normally you need only one if you have a subdomain for development and another for stage. The only problem is that I have not tested it on Umbraco v6...
    Have you downloaded the trial to see if everything is ok with this extension and Umbraco v6? If you have a subdomain starting with dev. or stage. or test. you can use it without a license....
    Best regards,
    Spyros.
    Apr 10, 2014 @ 15:57
    Poornima Nayar
    I have not downloaded it yet. I amabout to though. My local and staging environments are on a totally different domain which means that I need to look at a different license? I can also check how easy would it be to set up subdomains for staging/dev. When you mean subdomain startign with stage. do you mean the url looks like stage.site-name.site-domain.com?
    Poornima
    Apr 10, 2014 @ 16:00
    Spyros Spyriadis
    If you have 2 or more domains maybe you would be better with an IP license.... The subdomain stage.site-name.site-domain.com seems just fine for testing yes!
    Apr 10, 2014 @ 16:37
    Poornima Nayar
    Thanks a lot. With the IP license can i use it across different IPs or tied down to a single IP?
    Poornima
  • Pat Mancini 5 posts 25 karma points
    Oct 22, 2014 @ 06:37
    Pat Mancini
    Hi Poornima Nayar / Spyros Spyriadis how did you go with this?
    Does it work with Umbraco v6? We are also interested in using it.
  • Craig100 1136 posts 2523 karma points c-trib
    Feb 02, 2015 @ 16:54
    Craig100
    A version 7 would be great. Would be happy to pay for a working package.
    Feb 03, 2015 @ 10:32
    Spyros Spyriadis
    I'll try to have one for you maybe by the end of the month... I'm a bit busy at the time! Sorry for the delay...
