IQueryable or Expression<Func<T, bool>> with Examine to Linq
I am using Linq to Examine, and I am trying to do a dynamic query.
I have the below code
Expression<Func<MyResultClass, bool>> query = x => true;
if (searchField.Any())
query.And(x => x.MyField.ContainsAny(searchField));
var indexManager = new Index<MyResultClass>(index).Where(query);
But it doesnt work, do you know if Linq To Examine support dynamic querys? Do you know another way to do it? Any issues in my code, Do I coding wrong?
Im sorry for getting back to you late. I will try this out and get back to you. In theory yes it should work. But I will test it out.
What happens if you initialise it with a query?
For some reason my account does not work so I create new one.
I tried to do it with query but I could not, I had a lot of issues. So I am doing raw query directly, without Examine to Linq.
From Umbraco.Examine.Linq I am using only SearchResultMapper
Hey
As of 1.1 you can just use multiple where clauses to solve your problem
