  • Jesper Ordrup 1019 posts 1528 karma points MVP
    Aug 01, 2012 @ 04:03
    Jesper Ordrup
    Version 4.8.x and not earlier?
    Awesome package! Thanks for sharing. It wont run below 4.8.x?
    Best
    Jesper
  • Jorge Lusar 150 posts 489 karma points
    Aug 01, 2012 @ 09:15
    Jorge Lusar
    Thanks Jesper.
    To be honest, it was working ok with v4.7.2 but then I wanted to support SqlCe as well and I broke the compatibility as it compiles against the SqlCe binaries from Umbraco 4.8.
    I'll try to make a new package which is compatible with v4.7.x but I won't promise :)
    In the meantime, you can grab the sourcecode from https://github.com/jorgelusar/miniprofiler-for-umbraco, remove the ProfiledSqlCeHelper.cs from the project, remove line 38-44 in MiniProfilerPackage.cs and remove the SqlCe dependencies from the project.
    You'll also need to add this in your web.config:
    <add key="umbracoReservedPaths" value="~/umbraco,~/install/,~/mini-profiler-resources" />
    <add key="EnableMiniProfiler" value="true" />
    <add key="EnableSqlMiniProfiler" value="true" />
    and in system.web/pages/controls
    <add tagPrefix="profiler" namespace="StackExchangeContrib.Profiling.UI" assembly="StackExchangeContrib.Profiling" />
    Hope this helps.
    J
    Aug 01, 2012 @ 10:15
    Jesper Ordrup
    Hi Jorge,
    Super! Thanks. I'll probably grab the source and give it a shot next week.
    Best
    Jesper
    Aug 01, 2012 @ 16:02
    Jorge Lusar
    2
    Hi Jesper,
    I have just uploaded a new version compatible with Umbraco 4.7.x but I have only tested it with CWS Starter Kit and Umbraco 4.7.2. You should be able to download this version from http://our.umbraco.org/FileDownload?id=4310.
    Aug 02, 2012 @ 00:56
    Jesper Ordrup
    Thanks Jorge. I'm very sure that this makes a lot of ppl very happy. I'm looking forward to trying it out.
    best
    Jesper
