  • Carlos 338 posts 472 karma points
    Aug 07, 2012 @ 00:24
    Carlos
    MiniProfiler Version for 4.7 version broke site
    We downloaded the Package for 4.7 and tried to install the .zip file to our site. When we installed it, it completely broke our website.  we got a 500 server error. We took out the .dll's and what references we could find to them in the web.config. Could there be anything else we are missing that it installed or changed?
  • Jorge Lusar 150 posts 489 karma points
    Aug 07, 2012 @ 00:27
    Jorge Lusar
    Hi Carlos,
    Which umbraco version are you using? 4.7.0, 4.7.1 or 4.7.1.1?
    Are you running on IIS6 or IIS7.x? Classic or Integrated mode?
    What's the error message you are getting?
    J
    Aug 07, 2012 @ 00:31
    Carlos
    Sorry.
    Umbraco 4.7.1.
    IIS 7.5
    Integrated
    Just getting a 500 internal Server Error.
    we just need to know what we need to do to remove it for now.
    Then if you have a fix or suggestion that would be awesome.
    Thanks.
    Aug 07, 2012 @ 00:32
    Carlos
    We are using 4.7.1.1 not 4.7.1.
     And we don't have server tracing on so we don't know of any of the errors that are thrown.
    Aug 07, 2012 @ 00:36
    Carlos
    We turned the error tracing on. This is what we got.
    UPDATED.
    HTTP Error 500.22 - Internal Server Error
    An ASP.NET setting has been detected that does not apply in Integrated managed pipeline mode.
    Detailed Error Information
    Module ConfigurationValidationModule
    Notification BeginRequest
    Handler ExtensionlessUrlHandler-Integrated-4.0
    Error Code 0x80070032
    Requested URL http://website.test.dmns.org:80/
    Physical Path D:\WebSites\dmns.org
    Logon Method Not yet determined
    Logon User Not yet determined
    Most likely causes:
    • This application defines configuration in the system.web/httpModules section.
    Things you can try:
    • Migrate the configuration to the system.webServer/modules section. You can do so manually or by using AppCmd from the command line - for example, %SystemRoot%\system32\inetsrv\appcmd migrate config "Default Web Site/". Using AppCmd to migrate your application will enable it to work in Integrated mode, and continue to work in Classic mode and on previous versions of IIS.
    • If you are certain that it is OK to ignore this error, it can be disabled by setting system.webServer/validation@validateIntegratedModeConfiguration to false.
    • Alternatively, switch the application to a Classic mode application pool - for example, %SystemRoot%\system32\inetsrv\appcmd set app "Default Web Site/" /applicationPool:"Classic .NET AppPool". Only do this if you are unable to migrate your application.
    (Set "Default Web Site" and "Classic .NET AppPool" to your application path and application pool name)
    Links and More InformationIntegrated mode is the preferred mode for running ASP.NET applications on IIS 7.0 and above.
    View more information ยป
    Aug 07, 2012 @ 00:50
    Jorge Lusar
    Hi Carlos,
    If you unzip the package, you'll find the dlls you can remove, so it should be safe to delete:
    • StackExchangeContrib.Profiling.dll
    • MiniProfiler.dll
    • WebActivator.dll
    Aug 07, 2012 @ 00:54
    Jorge Lusar
    Also if the web.config was modified, delete:
    <add key="EnableMiniProfiler" value="true" />
    <add key="EnableSqlMiniProfiler" value="true" />
    and in system.web/pages/controls
    <add tagPrefix="profiler" namespace="StackExchangeContrib.Profiling.UI" assembly="StackExchangeContrib.Profiling" />
    Hope this helps. J
    Aug 07, 2012 @ 01:04
    Carlos
    Ok we backed out our web.config file to an earlier version we had from a week ago and now the site came back up.  I saw on your other forum you tested it on 4.7.2, but not 4.7.1 or 4.7.1.1.  Do you plan to?
    Thanks, the package looks very promising. We plan, on upgrading our Umbraco version at the end of the year.  We are a large organization and can only upgrade at certain times as not to bring down our public site.
    Thanks.
    Aug 07, 2012 @ 01:20
    Jorge Lusar
    Hi Carlos,
    I'm afraid I have not had the time to test it in 4.7.1 and 4.7.1.1. I'll try to find some time this week to have a quick look.
    The interesting thing is that what MiniProfiler is doing is registering and HttpModule using the WebActivator as in MiniProfilerPackage.cs, so I'm guessing it might be related to this. You could also try to getting the source code for github and manually registering the MiniProfilerStartupModule.cs.
    J
