  • Adrian 38 posts 117 karma points
    Aug 20, 2013 @ 14:36
    Adrian
    Profiler replaces macros output with green bordered box and debug message.
    Hi, I was looking into why my page was taking a few seconds to load. I thought I should have a look at the in built mini profiler....
    But when I enable it, it replaces navigation menu with a green box:
    Green Box
    It looks like it relates to my only XSLT macro on the page called Top Menu.
    Why is this happening? The xslt is basically one of the template navigation ones with a few tweaks....
    Ade
  • Jorge Lusar 150 posts 489 karma points
    Aug 20, 2013 @ 15:22
    Jorge Lusar
    Hi Adrian,
    If you referring to this package which is compatible with 4.8.0, 4.7.1.1 and not part of Umbraco Core, then that would be very strange as the css class is using is jquery.tooltip.css.
    If yo are taking about the new built-in miniprofiler on Umbraco 6.x, then I'm afraid I cannot help you as it is not part of this package and I guess you would have to post it in a Umbraco Core Thread.
    Regards,
    Jorge
    Aug 20, 2013 @ 15:26
    Adrian
    ooop yes it the built-in profiler so its Umbraco 6+, i'll post this into Core
