  • Michael Lawrence 128 posts 200 karma points
    May 11, 2011 @ 03:55
    Michael Lawrence
    Error creating relationships in Umbraco 4.7 using MS SQL CE 4
    Here's the error I get when trying to create a relationship. I had originally posted this error on Codeplex ( http://umbracorelationtypes.codeplex.com/workitem/436 ) over a month ago and it seems to still persist in Umbraco 4.7 final. Any idea if SQL CE 4 will be supported?
    Error running Scalar:
    SQL Statement:
    INSERT INTO umbracoRelationType (dual, parentObjectType, childObjectType, name, alias) VALUES (0, 'c66ba18e-eaf3-4cff-8a22-41b16d66a972', 'c66ba18e-eaf3-4cff-8a22-41b16d66a972', 'Related Page', 'relatedPage'); SELECT MAX (id) FROM umbracoRelationType
    Exception:
    System.Data.SqlServerCe.SqlCeException: There was an error parsing the query. [ Token line number = 1,Token line offset = 211,Token in error = SELECT ]
    at System.Data.SqlServerCe.SqlCeCommand.ProcessResults(Int32 hr)
    at System.Data.SqlServerCe.SqlCeCommand.CompileQueryPlan()
    at System.Data.SqlServerCe.SqlCeCommand.ExecuteCommand(CommandBehavior behavior, String method, ResultSetOptions options)
    at System.Data.SqlServerCe.SqlCeCommand.ExecuteScalar()
    at SqlCE4Umbraco.SqlCeApplicationBlock.ExecuteScalar(String connectionString, CommandType commandType, String commandText, SqlCeParameter[] commandParameters) in C:\work\codeplex\hgUmbraco\components\SQLCE4Umbraco\SqlCeApplicationBlock.cs:line 42
    Exception Details: SqlCE4Umbraco.SqlCeProviderException: Error running Scalar:
    SQL Statement:
    Exception:
    Source Error:
    Stack Trace:
    [SqlCeProviderException: Error running Scalar:
    SQL Statement:
    Exception:
    at SqlCE4Umbraco.SqlCeApplicationBlock.ExecuteScalar(String connectionString, CommandType commandType, String commandText, SqlCeParameter[] commandParameters) in C:\work\codeplex\hgUmbraco\components\SQLCE4Umbraco\SqlCeApplicationBlock.cs:line 42]
    SqlCE4Umbraco.SqlCeApplicationBlock.ExecuteScalar(String connectionString, CommandType commandType, String commandText, SqlCeParameter[] commandParameters) in C:\work\codeplex\hgUmbraco\components\SQLCE4Umbraco\SqlCeApplicationBlock.cs:50
    SqlCE4Umbraco.SqlCEHelper.ExecuteScalar(String commandText, SqlCeParameter[] parameters) in C:\work\codeplex\hgUmbraco\components\SQLCE4Umbraco\SqlCEHelper.cs:59
    umbraco.DataLayer.SqlHelper`1.ExecuteScalar(String commandText, IParameter[] parameters) +160
    [SqlHelperException: Umbraco Exception (DataLayer): SQL helper exception in ExecuteScalar]
    umbraco.DataLayer.SqlHelper`1.ExecuteScalar(String commandText, IParameter[] parameters) +221
    Umbraco.RelationTypes.NewRelationType.AddButton_Click(Object sender, EventArgs e) +343
    System.Web.UI.WebControls.Button.OnClick(EventArgs e) +118
    System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +112
    System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
    System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
    System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5563
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
  • Barry Fogarty 493 posts 1129 karma points
    Dec 02, 2011 @ 00:00
    Barry Fogarty
    Yeah I also get this exact error on SQL CE4 (Umbraco 4.7.1)
    Its a strange one as I ran the query in the database without a problem.
