Sorry this is a duplicate in another forum section, but I thought this section more appropriate
I am having a problem with the grid indexer code when deploying to Live.
Basically the indexer fails and none of the pages are available.
System.Exception: Error indexing queue items,System.MissingMethodException: Method not found: '!!0[] System.Array.Empty()'.
at NRP.Web.Helper.ExamineIndexer.OnExamineGatheringNodeData(Object sender, IndexingNodeDataEventArgs e)
at UmbracoExamine.UmbracoContentIndexer.OnGatheringNodeData(IndexingNodeDataEventArgs e)
at Examine.LuceneEngine.Providers.LuceneIndexer.GetDataToIndex(XElement node, String type) in x:\Projects\Examine\Examine\Projects\Examine\LuceneEngine\Providers\LuceneIndexer.cs:line 1113
at Examine.LuceneEngine.Providers.LuceneIndexer.ProcessIndexQueueItem(IndexOperation op, IndexWriter writer) in x:\Projects\Examine\Examine\Projects\Examine\LuceneEngine\Providers\LuceneIndexer.cs:line 1805
at Examine.LuceneEngine.Providers.LuceneIndexer.ProcessQueueItem(IndexOperation item, ICollection`1 indexedNodes, IndexWriter writer) in x:\Projects\Examine\Examine\Projects\Examine\LuceneEngine\Providers\LuceneIndexer.cs:line 1581
at Examine.LuceneEngine.Providers.LuceneIndexer.ForceProcessQueueItems(Boolean block) in x:\Projects\Examine\Examine\Projects\Examine\LuceneEngine\Providers\LuceneIndexer.cs:line 1539, IndexSet: NrpSearch
Works fine locally.
I am using your code with amendments to point to my indexer called"NrpSearchIndexer"
Changing the event to Application "Started" or "Starting" makes no change.
.OnExamineGatheringNodeData: Method not found
Works fine locally.
I am I missing something obvious. Feels like it.
Now thinking this is a .net Framework issue?
After some testing on a .NET 4.6. Its not that.
Any ideas?
