  • Scott Severance 13 posts 123 karma points
    Nov 09, 2017 @ 20:58
    Scott Severance
    Instalation of Skybrud.Umbraco.GridData
    I have followed instructions for setting up this package and set up a template based on examples you have provided in various sources. I believe I have failed to set this up correctly based on instructions provided.
    I have downloaded the zip folder. I have manually taken dlls and xml files from the release folder and dropped into my bin folder and restarted my app pool. Is this not correct? I found those instructions on grid.skybrud.dk but I still get null object reference in my search results page when attempting to reference the grid in my search results template file like this:
    @using Skybrud.Umbraco.GridData
    @using Skybrud.Umbraco.GridData.Extensions
    @inherits UmbracoTemplatePage
        Layout = "Master.cshtml";
        GridDataModel grid = Model.Content.GetGridModel("grid");
        if (grid.IsValid) {
            @grid.GetHtml(Html, "fanoe")
    if (grid.IsValid) is null
    Thank you for any help you may offer.
  • Anders Bjerner 487 posts 2996 karma points MVP 8x admin c-trib
    Jun 28, 2018 @ 17:12
    Anders Bjerner
    Hi Scott,
    I've first seen your question now.
    Is this still an issue? If so, what version of Umbraco and my package are you running?
    Both your code and your approach for installing the package seems fine.
    Aug 02, 2018 @ 18:46
    Scott Severance
    Hi Anders,
    No problem. I think my account has been flagged until recently. I held off further replying to this reply because I thought maybe I might come back around to it. However, in short, I have decided on moving away from the grid altogether. It's not a good fit. I do appreciate you taking the time to comment. Thank you. I will try and resovle this thread.
