I'm using Umbraco 7.3.0 beta 3 and SQL Server 2014.
Happy to report that almost everything works. After install, I got an error
Could not load control /UserControls/SQLBackUp/SQLBackUp.ascx
but I found the ascx file in /usercontrols. I created a SQLBackUp directory and moved the file into it and everything works great.
Hey Jon,
Thanks for flagging this. I've not yet tested in the latest release so I will add this as priority.
Regards
bump
Apologies for reviving the topic, but I am having the same issue in version 7.4.3, but can't find the .ascx file anywhere....
Hi Andrew,
Can you let me know what SQL server you are using, please? I've tested this with Umb 7.4.3 on SQL 2012, Express 2012 and Express 2014.
The control should be under /usercontrols/sqlbackup/sqlbackup.ascx
I've got some time scheduled in to look at various issues with the Package week commencing 18th Sept - I'm currently on holiday.
I'll post back once I have more to report and will hopefully have this resolved for you (and all).
Install problem
Hey Jon,
Regards
bump
Hi Andrew,
Hi Andrew,
