System.OverflowException: Value was either too large or too small for an Int32.
at System.Convert.ToInt32(Double value)
at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltArgument(XmlQueryType xmlType, Object value, Type destinationType)
at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, XPathNavigator {urn:schemas-microsoft-com:xslt-debug}current)
at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument,
XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter
writer)
at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String
fileName, String oldName, String fileContents, Boolean ignoreDebugging)
Can you post an example of an INSERT SQL command
I have tried several combonations with no success.
Which did you try?
What happend?
Error occured
at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer)
at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
Can you help?
Hi Shannon,
Sorry it took so long. Yup.
Download the new version 2 - http://our.umbraco.org/projects/developer-tools/sql-for-xslt-(jespercom)
Use the other method "jesper.sql:SQLExecuteScalar" for sqlstatements like INSERT, UPDATE, DELETE.
Fix the error in your xslt file:
<xsl:variable name="url" select="umbraco.library:NiceUrl(@id)"/>
<xsl:variable name="node" select="(@id)"/>
should be:
<xsl:variable name="url" select="umbraco.library:NiceUrl($currentPage/@id)"/>
<xsl:variable name="node" select="$currentPage/@id)"/>
Good luck
Jesper
Is there any way to remove the first bullet from the sample text?
Sure .. just remove the <li/>
Pls. remember to mark any of my responses as solution.
/Jesper
