  • bowling 4 posts 24 karma points
    Apr 24, 2012 @ 05:36
    bowling
    SQL for XSLT (Jesper Package)
    I've already installed Jesper Package to use SQL command in my xslt.
    However, I don't understand about configuring to another db
    I've already add the following to my web.config
      <add key="MYOWNDB" value="server=127.0.0.1;database=shop;user id=shop;password=99999999" />
    but i still can't select data from table in db .
    I changed xslt to
    <xsl:variable name="sqlexp">
    SELECT *
      FROM [MyTable]
    </xsl:variable>
    and when i press save , it said cannot find [MyTable]
    what should i do ??
    Please help .
  • Jesper Ordrup 1019 posts 1528 karma points MVP
    Apr 24, 2012 @ 07:08
    Jesper Ordrup
    When calling SQLXML you should add the second parameter specifying the database key from web.config
    <xsl:variablename="sqlresult"select="jesper.sql:SQLXml($sqlexp,'MYOWNDB')"/>
    best
    Jesper
