  • Patrick 10 posts 33 karma points
    Feb 17, 2011 @ 05:04
    Patrick
    Standard Values for "Today" for Date Picker
    I am wondering if its possible to put the current date as standarad value in a date picker control. I tried to input $date$ in the textbox of the date picker, but it doesn't work because its not a value date format. Thank you.
  • Morten Christensen 596 posts 2773 karma points admin hq c-trib
    Feb 18, 2011 @ 10:30
    Morten Christensen
    Hi Patrick,
    DatePicker is currently not supported, but will added in the next update.
    - Morten
    Mar 10, 2011 @ 04:28
    Patrick
    3
    I've gotten a work around, i entered 1900-01-01 in the standard value of a date picker field, then in the StandardValue.config, put the below line:
    <key name="01/01/1900 00:00:00" type="date">yyyy-MM-dd</key>
    And it works perfectly now.
  • Johan 188 posts 380 karma points
    Nov 03, 2011 @ 16:34
    Johan
    Thanks Patrick. Works perfect!
  • Connie DeCinko 931 posts 1160 karma points
    Dec 21, 2012 @ 17:25
    Connie DeCinko
    I recently changed my language file (en.xml) from en-GB culture to en-US.  This causes my standard value for date pickers to fail.  Today's date is no longer selected/inserted.  I have been trying various formats with no luck. Anyone figure this one out?
    Dec 21, 2012 @ 19:44
    Connie DeCinko
    "DatePicker is currently not supported, but will added in the next update."
    I'm not seeing this as being fixed in the latest version.  Was it?
  • Matt Taylor 873 posts 2086 karma points
    Mar 28, 2013 @ 14:43
    Matt Taylor
    I would like this too but can't see it in v1.6.
  • Eric Schrepel 161 posts 226 karma points
    Apr 22, 2013 @ 19:47
    Eric Schrepel
    Agreed; the only thing I need Standard Values package for is to add today's date as a default date, yet even in 1.6 it's not clear how to do this. Quick multi-screen-shot documentation possible?
    Apr 23, 2013 @ 10:31
    Matt Taylor
    Add this to the StandardValue.config and it should work.
    <key name="1900/01/01 00:00:00" type="date">yyyy-MM-dd</key>
  • Sudeep 1 post 21 karma points
    Sep 16, 2013 @ 05:36
    Sudeep
    Depending on your DateTime format setup (in SQL Server as well), the key name/value format will need to match. The following worked for me:
    <key name="01/01/1900 00:00:00" type="date">yyyy-dd-MM</key>
    If it is not working for you and you are not sure about the format, the best/quickest way to troubleshoot is to get the source and put a breakpoint at /BusinessLogic/StandardValue.cs > SetDocumentProperties() method. You can then check what your Key is traslated to by the Date Picker field, and what your value is converted to.
    This was tested with Umbraco 4.11.10
