I installed the package, but in Setting sections not exists the "standard value" folder..
I try logout and refresh setting folder but nothing...
-emiliano-
Are you logging in with the standard 'admin' user?
You might need to recycle the app pool or do an iisreset if the site is running on your local machine to have the section properly updated.
ok, thank you!
I recicle the pool
No joy, recycled IIS and the app pool and still not seeing the folder.
Standard Values Folder not Exists (Umbraco 6.0.5 - asp.net 4)
-emiliano-
ok, thank you!
I recicle the pool
