I can't get Standard Values to work. I see the tree in the Settings section and I can edit the values, but when I create a new node in Content the defined values are not entered, exactly as if Standard Values was not installed.
I've tred reinstalling, restarting IIS Express and cursing, but nothing helps. Is there any log I can check to see why it is not working?
I've finally found a solution to this problem. By calling the Save method on the ContentService at the end of Sitereactor.StandardValues.Events.InsertStandardValueInDocument.
My updated InsertStandardValueInDocument looks like this:
public class InsertStandardValueInDocument : ApplicationBase
public InsertStandardValueInDocument()
ContentService.Created += ContentService_Created;
void ContentService_Created(IContentService sender, Umbraco.Core.Events.NewEventArgs<Umbraco.Core.Models.IContent> e)
var content = e.Entity;
var repository = new Repository();
if(repository.NodeExists(content.ContentTypeId) == false)
return;
var service = new Service(repository);
service.SetStandardValueProperties(sender, content);
sender.Save(content);
I don't know if this the correct way to solve the problem, but it works (at least in Umbraco 6.1.5).
Values are not inserted (Umbraco 6.1.3)
Today I tried an empty install using Web Matrix. The only change I made was changing it to use MVC templates instead of WebForms, still nothing.
Unless somebody has any ideas I guess the next thing to do is download the source and add some logging so I can perhaps figure out where it fails.
Tor, were you able to get this to work on Umbraco 6.2.5? I cannot even get the folder to display.
We have pretty much stopped using StandardValues so I've never tried it on 6.2.5
So is no one needing to set default values anymore? Any other packages out there?
is there an update that includes this fix? i have the same problem.
