  • Antony Briggs 78 posts 103 karma points
    Aug 15, 2014 @ 17:35
    Antony Briggs
    Umbraco v7.1.4: umbraco.interfaces.IDataEditor is a legacy object and is not supported by runtime
    I realise that this package hasn't been tested much on v7 yet but you gotta start somewhere!
    The package installs fine on v7.1.4 but when you try to load a docType under the "Standard Values" tree I get the following error:
    NotSupportedException: umbraco.interfaces.IDataEditor is a legacy object and is not supported by runtime generated umbraco.interfaces.IDataType instances to maintain backwards compatibility with the legacy APIs. Consider upgrading your code to use the new Services APIs.]
       Umbraco.Core.PropertyEditors.BackwardsCompatibleDataType.get_DataEditor() +165
       umbraco.controls.ContentControl.AddControlNew(Property p, TabPage tp, String cap) +94
       umbraco.controls.ContentControl.LoadPropertyTypes(IContentTypeComposition contentType, TabPage tabPage, Hashtable inTab, Int32 tabId, String tabCaption) +254
       umbraco.controls.ContentControl.CreateChildControls() +503
       System.Web.UI.Control.EnsureChildControls() +83
       umbraco.uicontrols.TabView.OnInit(EventArgs e) +22
       umbraco.controls.ContentControl.OnInit(EventArgs e) +29
       System.Web.UI.Control.InitRecursive(Control namingContainer) +134
       System.Web.UI.Control.AddedControl(Control control, Int32 index) +191
       System.Web.UI.ControlCollection.Add(Control child) +86
       Sitereactor.StandardValues.EditStandardValue.OnInit(EventArgs e) +954
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +489
