My U7.28 Back End is extremely slow. Is it possible to set sticky profiler to run on the back office ?
Hi Anton
Do you have any plugins installed or custom tree's? I can't see why you can't install Glimpse?
Hi Anton,
I'm not at all sure the mini profiler works for the backend. Sorry.
Are you sure your slow backend is caused by the server side? It could also be that some badly performing plugin or content editor is killing your performance in the browser.
-Kenn
Hi Thanks.
I don't know. This is what I'm trying to ascertain. It seems like it is server side.
I get white screens all over and I have to refresh the browser a couple of times to get anything displayed. From login to tree changes.
Any advice will be appreciated
Anything in the JS console?
Which browser (version) are you using?
Sticky Profiler for Backend
Hi Anton
Hi Anton,
-Kenn
Hi Thanks.
