We had problems with versions 7.0.0 and 7.1.0 as the uHateoas package is reliant on GetUmbracoAuthTicket, which doesn't seems to be supported by the earlier versions of Umbraco 7.1.x
Good news is that it works fine with version 7.1.5 and up!
If you want to get started now with REST and Hypermedia for Umbraco, check out the project : https://our.umbraco.org/projects/developer-tools/uhateoas-umbraco-hypermedia-as-the-engine-of-application-state/
Upload image
uHateoas works with Version 7.1.5 and upwards
