So I assume you are running this in list view mode? And SortColumn = "ActivityStartTime", SortOrder = "desc" should be the initial sort of the list view?
Looks like it is just something that isn't implemented currently (but won't be hard) the sortcolum and sortorder will affect the rendering of the tree not the listview so something I forgot
Changes pushed, new version is building (for the dates seems someone from the community has created a filter option for that, so asked them to submit a pull request)
Sort order not working.
This is not working for me.. SortColumn = "ActivityStartTime", SortOrder = "desc"
Comment author was deleted
Must be related to sorting on dates, I'll take a look
Great, also is there a way to make the date look better, remove the T and Z ?
2016-01-21T00:00:00Z
Any news on this?
Not yet sorry been busy with other stuff but it's on the todo for this week
Giving it a shot now, will report back with more details
Will add now and report back
Tim, right on the spot, thats what we are trying to do. Also in another matter we are trying have one view that only lists todays bookings.
Ok just made the necessary changes, will do some more tests and release a new version later today
New version is up https://www.nuget.org/packages/Nibble.Umbraco.UIOMatic/ (v 1.6.1)
Superthanks yet again Tim!!
No problem, glad I can help! And must say I'm curious to see how you are using the package :)
