What am I doing wrong, ...
This wont work.
e.Query.Where("BookingCategory = 'Child'");
or this..
e.Query.Where("BookingCategory = @0","'Child'");
(Column name is "BookingCategory")
Comment author was deleted
In which event are you doing this?
public class EventHandlerscs4 : ApplicationEventHandler { protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext) { UIOMatic.Controllers.PetaPocoObjectController.BuildingQuery += PetaPocoObjectController_BuildingQuery; }
void PetaPocoObjectController_BuildingQuery(object sender, UIOMatic.QueryEventArgs e) { if (e.CurrentType == typeof(tcAdminTodaysChildActivity)) { var DateNow = DateTime.Now; var theDate = Convert.ToDateTime(DateNow.ToString("yyyy-MM-dd")); e.Query.Where("HotelSiteRootId = @0 AND BookingCategory = 'Child' AND DATEPART(yy, ActivityStartTime) = " + theDate.Year + " AND DATEPART(mm, ActivityStartTime) = " + theDate.Month + "AND DATEPART(dd, ActivityStartTime) = " + theDate.Day + "", UmbracoContext.Current.Security.CurrentUser.StartContentId); } } }
So the other filters work? Or they all fail?
The other filters work fine, both HotelSiteRootId (int) and Date (DateTime).
Hmm don't see why it shouldn't work, are you sure the correct code is getting executed?
SQL
This wont work.
or this..
