  • Jay 425 posts 652 karma points
    Nov 15, 2017 @ 10:47
    Jay
    Multiple UI-O-Matic model types found with alias 'companies'
    hi Tim,
    My UI O Matic section dashboard is not loading.
    I got a weird error as below which works on local but not on our Dev environment which is in Azure.
    I've doubled check that there's only one single alias in use. Can't figure out why. Any idea?
        Unhandled controller exception occurred
    System.ApplicationException: Multiple UI-O-Matic model types found with alias 'companies'. Please ensure all types have a unique alias value.
    at UIOMatic.Helper.EnsureUIOMaticTypes()
    at UIOMatic.Helper.GetUIOMaticFolderTypes()
    at UIOMatic.Helper.GetUIOMaticTypes()
    at UIOMatic.Web.Controllers.ObjectController.GetSummaryDashboardTypes()
    at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)
    at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
    at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()
    at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
    at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()
    at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext()
    at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
    at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()
    at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext()
    at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__0.MoveNext()
    Nov 15, 2017 @ 11:21
    Jay
    Is there a local cache somewhere that I need to clear / remove btw?
    Nov 20, 2017 @ 14:57
    Jay
    Hey Tim,
    Found the below,
    Do you remember in Helper.cs (line 35-40), why this has been changed from the previous version?
    https://github.com/TimGeyssens/UIOMatic/commit/ce9733fa6075affe44702d6db87dd155ad9aa738
  • Comment author was deleted
    Nov 20, 2017 @ 15:33
    Yes it's due to something I wanted to support in MCFLY so it can also find types that are generated at runtime. And the Umbraco Core typefinder didn't support this...
    Nov 20, 2017 @ 16:10
    Jay
    Hi Tim,
    What's MCFLY btw?
    Nov 20, 2017 @ 16:17
    http://www.nibble.be/?p=538 it generates the ui-o-matic types based on a UI, so a simple form builder
    Nov 20, 2017 @ 16:21
    Jay
    Ic. Looks awesome.
    Oh yeah have you come across the error above that keeps saying found alias (but there's only one single one), it seems to happen randomly, can't find a way to trigger it and I've only got one alias with that type.
    Nov 20, 2017 @ 16:24
    Hmm I'll see if I can reproduce, if it fails we could just not throw the exception... not pretty but it should work
    Nov 20, 2017 @ 16:30
    Jay
    Thanks Tim :)
