  • Ali Sheikh Taheri 470 posts 1648 karma points c-trib
    Dec 12, 2018 @ 13:15
    Ali Sheikh Taheri
    How to reference property editors
    Hi Tim,
    I have created a new drop-down list property editor of type "UIOMatic Dropdown", how can I specify a field to use this editor?
    I believe this property editor is not saved on the file system so I can't use the View option in "UIOMaticFieldAttribute".
    Your documentation here shows how to create one but doesn't show an example of how it can be referenced in the code.
    Your help is much appreciated.
    Ali
  • Comment author was deleted
    Dec 12, 2018 @ 13:45
    Dec 12, 2018 @ 13:51
    Ah ok you want to use a prop editor as a field view? Not sure that is possible plug and play...
    Dec 12, 2018 @ 13:55
    Ali Sheikh Taheri
    Yes that's correct, it would be great if there was a possibility of resuing that as field editor instead of this:
    [UIOMaticField(Description = "Select the owner of the dog", View = UIOMatic.Constants.FieldEditors.Dropdown,
       Config = "{'typeAlias': 'person', 'valueColumn': 'Id', 'sortColumn': 'FirstName', 'textTemplate' : '{{FirstName}} {{LastName}}'}")]
    public int OwnerId { get; set; }
    to be honest for the dropdown list is fine but for ListView is way more useful as it gives options like hiding create or delete button.
