  • Thomas Stock 40 posts 70 karma points
    Dec 09, 2010 @ 12:02
    Thomas Stock
    Source code
    I was wondering if you would be willing to share the source code of the installation target directory choice thingy.
    I assume this is UmbracoProjectWizard.dll in your Project Template?
    The reason I'm asking is because I'd like to extend/make something similar. I currently start from your project but then always have to manually remove/add some things..
    If you do not feel comfortable sharing your source code, could u let me know where you found info on how to incorperate such wizard in a Project Template?
    thanks!
    Dec 09, 2010 @ 23:25
    Thomas Stock
    update:
    I found a tutorial on how to create such wizard. I think I can just use yours without making changes, I just have to change the project template definition etc it seems.
    I'm going to further investigate what would be the best approach for what I'm trying to achieve.
    I'll keep you up to date, of course I wont use your stuff without permission etc.
  • Malte Baden Hansen 61 posts 158 karma points
    Dec 14, 2010 @ 17:48
    Malte Baden Hansen
    Hi =)
    I wouldn't mind sharing the source code, and if anyone is interested in contributing to further development of the project, that'd be awesome.
    Please keep me posted on your progress =)
