Hi, many thanks for contributing this project, it's a great starting point for source control oriented Umbraco development. I just thought I'd let you know that I've updated it to include the macroScripts folder as well, and I can give you this file if you want to update the project page?
Updated Project Template
Thanks again,
Paul
Currently i'm not sure where the source files is, had some hardware failure a while back.
You modified the xcopy commands to include the macroscripts?
I will see what i can do :)
Any luck finding the source?
I'd like to see macro scripts added and have access to the source to make some customizations if possible.
