  • sdfsfm 70 posts 94 karma points
    Aug 06, 2010 @ 16:59
    sdfsfm
    moving the cws contact files to another site thats doesn't have cws installed.
    Hi I know Warren is on holiday at the moment but I was wondering if someone else could help. Basically i've copied over the cws  contact files (the ascx for the form and dashboard, the doc type). I've create the contact macro which calls the ascx, but The form isn't showing on the page.
    Has any one else had a similar problem?
  • Darren Ferguson 1022 posts 3259 karma points MVP c-trib
    Aug 06, 2010 @ 17:16
    Darren Ferguson
    How about the DLLs in the /bin directory?
    sdfsfm
    I figured out what i was doing wrong. Basically the docType was out of my master document type and wasn't inheriting correclty therefore showing a blank page.
    I was also missing the form_log.xslt file under the data folder
  • Warren Buckley 2106 posts 4836 karma points MVP 8x admin c-trib
    Aug 23, 2010 @ 14:15
    Warren Buckley
    Hi Ivor I am glad you managed to find the problem.
    Warren :)
